Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
Use a T10 Torx driver to remove the two 7.5 mm screws securing the logic board.
Place a thumb at each end of the exhaust vent, over the fan screw holes.
Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
