Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your fan is noisy or clogged with dust, use this guide to remove it for cleaning or replacement.
O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
Three 4.1 mm shoulder screws
Three 1.8 mm screws
Use a T6 Torx driver to remove the four 7.2 mm screws securing the fan:
Two screws securing the fan to the logic board
Two screws securing the fan to the exhaust vent
7 outras pessoas executaram este guia.
2 comentários
Hi, thank you for this guide. I am getting ready to do the same. Regarding the fan connector: is it perhaps the slide-in type which can be disconnected by pulling the wires horizontally backwards, instead of pulling upwards? The photos are good but still not enough magnification to be able to tell. Thanks in advance.
It appears to be the type of connector to slide laterally rather than needing to be pulled vertically in order to be disconnected.
Zac Hall -
