Ir para o conteúdo principal
Mac mini Late 2014 PCIe SSD Cable Replacement
O que você precisa
  1. Mac mini Late 2014 PCIe SSD Cable Replacement, Bottom Cover: passo 1, imagem 1 %32
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
    Pergunte ao FixBot
    Comentar
  2. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    Pergunte ao FixBot
    Comentar
  3. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 3, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 3, imagem 2 %32
    • Lift and remove the bottom cover.
    Pergunte ao FixBot
    Comentar
  4. Mac mini Late 2014 PCIe SSD Cable Replacement, Antenna Plate: passo 4, imagem 1 %32
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
    Pergunte ao FixBot
    Comentar
  5. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 5, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 5, imagem 2 %32
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
    Pergunte ao FixBot
    Comentar
  6. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 6, imagem 1 %32
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
    Pergunte ao FixBot
    Comentar
  7. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 7, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 7, imagem 2 %32
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    Pergunte ao FixBot
    Comentar
  8. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 8, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 8, imagem 2 %32
    • Carefully pull the antenna cable out from the gap between the power supply and case.
    Pergunte ao FixBot
    Comentar
  9. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 9, imagem 1 %32
    • Remove the antenna plate from the Mac mini.
    Pergunte ao FixBot
    Comentar
  10. Mac mini Late 2014 PCIe SSD Cable Replacement, SSD: passo 10, imagem 1 %32
    • Remove the 5 mm T5 screw securing the SSD.
    Pergunte ao FixBot
    Comentar
  11. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 11, imagem 3 %32
    • Lift the free end of the SSD up slightly and pull it out of its socket.
    Pergunte ao FixBot
    Comentar
  12. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 2 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 12, imagem 3 %32
    • Carefully lift the SSD out of the case without scratching or touching the gold contacts.
    Pergunte ao FixBot
    Comentar
  13. Mac mini Late 2014 PCIe SSD Cable Replacement, PCIe SSD Cable: passo 13, imagem 1 %32
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
    Pergunte ao FixBot
    Comentar
  14. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 14, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 14, imagem 2 %32
    • Remove the PCIe SSD cable bracket.
    Pergunte ao FixBot
    Comentar
  15. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 15, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 15, imagem 2 %32
    • Use the flat end of a spudger to lift the PCIe SSD connector straight up off of its connector on the logic board.
    • Be careful not to pry up on the socket itself.
    Pergunte ao FixBot
    Comentar
  16. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 16, imagem 1 %32 Mac mini Late 2014 PCIe SSD Cable Replacement: passo 16, imagem 2 %32
    • Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
    Pergunte ao FixBot
    Comentar
  17. Mac mini Late 2014 PCIe SSD Cable Replacement: passo 17, imagem 1 %32
    • Remove the PCIe SSD cable from the Mac mini.
    Pergunte ao FixBot
    Comentar
Conclusão
29 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.549 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.572 guias
8Comentários do guia
Where i can buy the PCIe SSD card?
melvin suarez - Responder Compartilhar
Where i can buy the PCIe SSD card, someone?
Claudio Vargas - Responder Compartilhar
I can supply these cables. Please reply to this thread.
Thomas Hall - Responder Compartilhar
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
Angelo - Responder Compartilhar
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
Daniel Abdulla - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 50
Últimos 30 dias: 198
Ao todo: 65,189
