Ir para o conteúdo principal
Mac Pro First Generation Optical Drive Replacement
O que você precisa
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Lift the lever to unlock the case
    Pergunte ao FixBot
    Comentar
  2. Mac Pro First Generation Optical Drive Replacement: passo 2, imagem 1 %32
    • Remove the side panel of the Mac Pro
    Pergunte ao FixBot
    Comentar
  3. Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 2 %32 Mac Pro First Generation Optical Drive Replacement: passo 3, imagem 3 %32
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
    Pergunte ao FixBot
    Comentar
  4. Mac Pro First Generation Optical Drive Replacement: passo 4, imagem 1 %32
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
    Pergunte ao FixBot
    Comentar
  5. Mac Pro First Generation Optical Drive Replacement: passo 5, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 5, imagem 2 %32
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
    Pergunte ao FixBot
    Comentar
  6. Mac Pro First Generation Optical Drive Replacement: passo 6, imagem 1 %32 Mac Pro First Generation Optical Drive Replacement: passo 6, imagem 2 %32
    • Firmly grasp the optical drive and pull it out of its enclosure.
    Pergunte ao FixBot
    Comentar
Conclusão
21 outras pessoas executaram este guia.
Derek Chan
Membro desde: 10/13/14
1.428 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-24, Maness Fall 2014 Membro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membros
Autoria de 19 guias
10Comentários do guia
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Responder Compartilhar
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Responder Compartilhar
Did you take off the front of the tray?
nbeijer - Responder Compartilhar
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Responder Compartilhar
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 69
Ao todo: 18,807
