Ir para o conteúdo principal
Mac Pro First Generation Hard Disk Drive (HDD) Replacement
O que você precisa
  1. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Case Panel: passo 1, imagem 1 %32
    • Lift the lever to unlock the case.
    Pergunte ao FixBot
    Comentar
  2. Mac Pro First Generation Hard Disk Drive (HDD) Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    Pergunte ao FixBot
    Comentar
  3. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Locate the Hard Drive Bays: passo 3, imagem 1 %32
    • Locate the desired hard drive bay after opening the case .
    • This is usually the drive closest to the front of the case.
    Pergunte ao FixBot
    Comentar
  4. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: passo 4, imagem 1 %32 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: passo 4, imagem 2 %32 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove the Hard Drive Bay: passo 4, imagem 3 %32
    • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
    • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
    Pergunte ao FixBot
    Comentar
  5. Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: passo 5, imagem 1 %32 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: passo 5, imagem 2 %32 Mac Pro First Generation Hard Disk Drive (HDD) Replacement, Remove metal Hard Drive sled: passo 5, imagem 3 %32
    • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
    • Locate the four 6-32 type screws on the Hard Drive sled.
    • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 6-24, Maness Fall 2014 Membro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 29
Últimos 30 dias: 141
Ao todo: 26,469
