Ir para o conteúdo principal
Mac Pro First Generation GPU Replacement
  1. Mac Pro First Generation GPU Replacement, Case Panel: passo 1, imagem 1 %32
    • Lift the lever to unlock the case.
    Pergunte ao FixBot
    Comentar
  2. Mac Pro First Generation GPU Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Remove the side panel of the Mac Pro.
    • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
    Pergunte ao FixBot
    Comentar
  3. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): passo 3, imagem 1 %32
    • Locate the graphics card in the open panel side of your Mac Pro.
    Pergunte ao FixBot
    Comentar
  4. Mac Pro First Generation GPU Replacement: passo 4, imagem 1 %32 Mac Pro First Generation GPU Replacement: passo 4, imagem 2 %32 Mac Pro First Generation GPU Replacement: passo 4, imagem 3 %32
    • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
    • Remove the slide lock.
    Pergunte ao FixBot
    Comentar
  5. Mac Pro First Generation GPU Replacement: passo 5, imagem 1 %32 Mac Pro First Generation GPU Replacement: passo 5, imagem 2 %32 Mac Pro First Generation GPU Replacement: passo 5, imagem 3 %32
    • Push up on the clip directly behind the graphics card to release it from its slot.
    • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
    • Handle the card only by its edges. Don't touch any exposed components or connectors.
    Pergunte ao FixBot
    Comentar
Conclusão
23 outras pessoas executaram este guia.
Andrew Kim
Membro desde: 10/12/14
1.263 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-24, Maness Fall 2014 Membro de Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membros
Autoria de 19 guias
8Comentários do guia
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - Responder Compartilhar
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - Responder Compartilhar
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - Responder Compartilhar
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - Responder Compartilhar
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 76
Ao todo: 23,871
