Ir para o conteúdo principal
Mac Powerbook 140 Hard Drive Replacement
O que você precisa
  1. Mac Powerbook 140 Hard Drive Replacement, Opening the computer(bottom): passo 1, imagem 1 %32
    • Turn the 140 upside down and remove the 4 screws in the bottom with a T10 star-headed screwdriver
    Pergunte ao FixBot
    Comentar
    • Being careful to hold the top and bottom halves of the computer together, turn to the back side of the computer and remove the final screw with a T17 Star-headed screwdriver.
    Pergunte ao FixBot
    Comentar
    • Slide the battery panel or switch(depending on your battery) toward the front of the computer, then pull the battery straight out.
    Pergunte ao FixBot
    Comentar
  2. Mac Powerbook 140 Hard Drive Replacement, Removing the screen/keyboard: passo 4, imagem 1 %32 Mac Powerbook 140 Hard Drive Replacement, Removing the screen/keyboard: passo 4, imagem 2 %32
    • CAREFULLY lift the back of the screen and keyboard unit(the top of the computer) and GENTLY push the front left and right corners away from the bottom unit until a click is heard. Then, SLOWLY lift the top unit and remove the interconnect cable (the large somewhat brittle cable connecting the two halves) from its socket in the sisterboard.
    Pergunte ao FixBot
    Comentar
    • Using the T-17 Star headed screwdriver, take out the screws holding in drive retainer that covers the hard drive and floppy disc drive. Some of these screws may be inserted very tightly. If any stick, CAREFULLY use a pair of needle-nosed pliers to twist the screw out.
    Pergunte ao FixBot
    Comentar
    • Now, remove the long, flat HDA cable from the hard drive by pulling the white plastic piece directly out of the bottom of the hard drive. Be sure to do this CAREFULLY, as the flat cable can easily become disconnected from the plastic piece. Should this happen, pull the top and bottom of the piece away from each other and GENTLY re-insert the cable.
    Pergunte ao FixBot
    Comentar
    • Locate your new and COMPATIBLE hard drive. Ensure that is is in proper working order and will not damage your computer or pose any health or safety risk to you.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Once complete, start up your computer to ensure the hard drive works. Should you have any issues, ensure all connections were made correctly and that all parts were properly replaces. For further questions, refer to this guide or to the iFixit Answers Forum.
Uma outra pessoa concluiu este guia.
Jack
Membro desde: 10/23/15
810 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 49
Ao todo: 1,830
