Ir para o conteúdo principal
MSI PR600 MS-16372 RAM Replacement
O que você precisa
  1. MSI PR600 MS-16372 RAM Replacement, Battery: passo 1, imagem 1 %32
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
    Pergunte ao FixBot
    Comentar
  2. MSI PR600 MS-16372 RAM Replacement: passo 2, imagem 1 %32
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
    Pergunte ao FixBot
    Comentar
  3. MSI PR600 MS-16372 RAM Replacement: passo 3, imagem 1 %32
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
    Pergunte ao FixBot
    Comentar
  4. MSI PR600 MS-16372 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Unscrew the four 10 mm Phillips head screws circled in red in the picture using the Phillips 00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. MSI PR600 MS-16372 RAM Replacement: passo 5, imagem 1 %32
    • Put your pointer finger underneath the tab and lift up to remove the plastic cover.
    Pergunte ao FixBot
    Comentar
  6. MSI PR600 MS-16372 RAM Replacement: passo 6, imagem 1 %32
    • Slide the RAM off by pulling it away from the fan.
    • Slide RAM back in to serve as a reset.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Lauren Mewes
Membro desde: 10/21/18
388 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S4-G8, Lore Fall 2018 Membro de UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 23
Ao todo: 736
