Introdução
If your MSI MS-1782 laptop has a totally black screen, or vertical or horizontal lines on the screen, it could be your GPU malfunctioning. Check the troubleshooting page to help you identify the problem. This guide will show you how to replace the GPU.
O que você precisa
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
