Ir para o conteúdo principal
MSI GS70 Battery Replacement
O que você precisa
    1. MSI GS70 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Make sure that the laptop is turned off before starting.
      • Place laptop with the bottom plate facing up.
      Pergunte ao FixBot
      Comentar
    2. MSI GS70 Battery Replacement: passo 2, imagem 1 %32
      • Remove all screws using the JIS #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. MSI GS70 Battery Replacement: passo 3, imagem 1 %32
      • Remove the back plate.
      • Locate the battery.
      Pergunte ao FixBot
      Comentar
    4. MSI GS70 Battery Replacement: passo 4, imagem 1 %32
      • Locate the foil connector above the battery.
      Pergunte ao FixBot
      Comentar
    5. MSI GS70 Battery Replacement: passo 5, imagem 1 %32
      • Flip up both black clips with your spudger.
      Pergunte ao FixBot
      Comentar
    6. MSI GS70 Battery Replacement: passo 6, imagem 1 %32
      • Remove the foil connector by pulling on the blue tabs.
      Pergunte ao FixBot
      Comentar
    7. MSI GS70 Battery Replacement: passo 7, imagem 1 %32
      • After the foil connector is removed you will see an 8 pin connector.
      • Disconnect the 8 Pin connector.
      Pergunte ao FixBot
      Comentar
    8. MSI GS70 Battery Replacement: passo 8, imagem 1 %32
      • Lift the battery and remove.
      Pergunte ao FixBot
      Comentar
Conclusão
11 outras pessoas executaram este guia.
5Comentários do guia
Perfect guide
storolle - Responder Compartilhar
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Responder Compartilhar
Which battery model should I buy?
slackware2007 - Responder Compartilhar
BTY-L76 seems like a good fit
uchadhana (다나) - Responder Compartilhar
I want to replace the battery and lcd cover of the msi gs72 6qe stealth pro. Are the msi gs70 parts compatible with the msi gs72? because I have difficulty finding msi gs72 parts in my country (indonesia)
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 50
Ao todo: 10,120
