Ir para o conteúdo principal
MSI GS66 Stealth 11UE-007 RAM Replacement
O que você precisa
  1. MSI GS66 Stealth 11UE-007 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device from any outlet.
    Pergunte ao FixBot
    Comentar
  2. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 2, imagem 1 %32
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
    Pergunte ao FixBot
    Comentar
  3. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 3, imagem 1 %32
    • Remove eight 10 mm Phillips #1 screws.
    Pergunte ao FixBot
    Comentar
  4. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 4, imagem 1 %32
    • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
    Pergunte ao FixBot
    Comentar
  5. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, imagem 1 %32 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, imagem 2 %32 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, imagem 3 %32
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
    Pergunte ao FixBot
    Comentar
  6. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 6, imagem 1 %32 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 6, imagem 2 %32
    • Lift back black plastic.
    Pergunte ao FixBot
    Comentar
  7. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 7, imagem 1 %32 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 7, imagem 2 %32
    • Place both thumbs on metal tabs and apply pressure in a widening motion until RAM lifts.
    Pergunte ao FixBot
    Comentar
  8. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 8, imagem 1 %32
    • Pull RAM straight out from the connector at the angle it lifted at.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 48
Ao todo: 1,017
