Introdução
In this guide we will be replacing the battery for the MSI FORCE GC30 V2; model number/name: MSI FORCE GC30 V2. The battery is the main source of power for the device, and there are a few symptoms of a bad battery that is in need of replacements. Symptoms include short battery life after full charge, and no power is present in the device.
O que você precisa
Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
Remove the six 9.2 mm-long Phillips #0 screws.
Use tweezers to grip the white battery connector.
Pull the battery connector directly out of its port.
For optimal performance, calibrate your newly installed battery after completing this guide.
