Introdução
This guide will show you how to replace your screen. To do so you will be taking the tablet completely apart. You will need the plastic opening tool and the screw driver with the PH 00 bit.
O que você precisa
Use the plastic opening tool to pull the screen away from the back plate. Once pulled away, remove the back plate completely.
Next you will want to remove the white wire tape with blue ends from the circuit board in the corner. Use the plastic opening tool to pull back on the locking mechanism on both sides of the socket. Once you have pulled back on both sides of the locking mechanism you can then pull the white wire tape out gently.
Opposite side of where we removed the small orange circuit board you will see a small green circuit board and this will need to be removed as well. Gently remove the green circuit board from the sticky pad.
After removing the green circuit board from the sticky pad, use your plastic opening tool to assist you in unplugging the circuit board. (similar to unplugging the battery) Once the circuit board is successfully unplugged you may remove it and set it to the side.
Next you will have to remove the wide orange wire tape which connects the screen to the circuit board.
Use the plastic opening tool to pull out the locking mechanisms on both sides of the socket.
Once the two are unlocked (shown in picture 2) you can then remove the orange tape gently.
Now that you have removed the 4 screws that hold the main circuit board into place, lift up on the circuit board while using the plastic opening tool to pop the speakers out of their mounts.
Once you have successfully removed the main circuit board you can put it to the side gently making sure not to damage it.
Uma outra pessoa concluiu este guia.
