Ir para o conteúdo principal
MID-7006 Battery Replacement
O que você precisa
    1. MID-7006 Battery Replacement, Battery: passo 1, imagem 1 %32 MID-7006 Battery Replacement, Battery: passo 1, imagem 2 %32
      • Use the plastic opening tool to pull the screen away from the back cover.
      Pergunte ao FixBot
      Comentar
    2. MID-7006 Battery Replacement: passo 2, imagem 1 %32 MID-7006 Battery Replacement: passo 2, imagem 2 %32
      • Once you have seperated the back plate and the screen from each other like so, you will then begin to lift the battery peeling it off of its sticky pads.
      Pergunte ao FixBot
      Comentar
    3. MID-7006 Battery Replacement: passo 3, imagem 1 %32 MID-7006 Battery Replacement: passo 3, imagem 2 %32
      • Unplug the battery at the plug indicated by the plastic opening tool. (The best way to do this is to place a finger on both sides of the plug and pull out gently) Once you have removed the old battery, plug the new battery into the same plug the old one came from.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Texas Tech, Team 38-1, Bennett Fall 2016 Membro de Texas Tech, Team 38-1, Bennett Fall 2016
TTU-BENNETT-F16S38G1
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 47
Ao todo: 549
