Ir para o conteúdo principal
Lorex LHV210800 Motherboard Replacement
O que você precisa
  1. Lorex LHV210800 Motherboard Replacement, Upper Case: passo 1, imagem 1 %32 Lorex LHV210800 Motherboard Replacement, Upper Case: passo 1, imagem 2 %32 Lorex LHV210800 Motherboard Replacement, Upper Case: passo 1, imagem 3 %32
    • Before beginning, disconnect the DVR from power and unplug all peripheries.
    • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
  2. Lorex LHV210800 Motherboard Replacement: passo 2, imagem 1 %32 Lorex LHV210800 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the four 1 cm Phillips screws on the rear panel.
    • Do not unscrew the screw connected to the lower case.
  3. Lorex LHV210800 Motherboard Replacement: passo 3, imagem 1 %32
    • Lift up and remove the top cover.
  4. Lorex LHV210800 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Lorex LHV210800 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Unscrew the 1cm hex screws with the driver and a size 8 hex socket.
    • Unplug the cord from the socket in the motherboard.
  5. Lorex LHV210800 Motherboard Replacement: passo 5, imagem 1 %32 Lorex LHV210800 Motherboard Replacement: passo 5, imagem 2 %32 Lorex LHV210800 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the two 1cm screws from the back panel.
    • This makes it easier to slide out with no issue.
  6. Lorex LHV210800 Motherboard Replacement: passo 6, imagem 1 %32 Lorex LHV210800 Motherboard Replacement: passo 6, imagem 2 %32
    • Once all the screws are off the back panel, remove the power source.
    • The power source would be the white box with the R/B/G cables attached, along with the blue and other white box with R/B/B/Y cords.
  7. Lorex LHV210800 Motherboard Replacement: passo 7, imagem 1 %32 Lorex LHV210800 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove this pin in order to take off the fan.
    • Remove the fan in order to access the motherboard.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Maxwell Cash
Membro desde: 02/19/25
387 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 203
