Ir para o conteúdo principal
Lorex LHV210800 Fan Replacement
O que você precisa
  1. Lorex LHV210800 Fan Replacement, Upper Case: passo 1, imagem 1 %32 Lorex LHV210800 Fan Replacement, Upper Case: passo 1, imagem 2 %32 Lorex LHV210800 Fan Replacement, Upper Case: passo 1, imagem 3 %32
    • Before beginning, disconnect the DVR from power and unplug all peripheries.
    • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
  2. Lorex LHV210800 Fan Replacement: passo 2, imagem 1 %32 Lorex LHV210800 Fan Replacement: passo 2, imagem 2 %32
    • Remove the four 1 cm Phillips screws on the rear panel.
    • Do not unscrew the screw connected to the lower case.
  3. Lorex LHV210800 Fan Replacement: passo 3, imagem 1 %32
    • Lift up and remove the top cover.
  4. Lorex LHV210800 Fan Replacement, Fan: passo 4, imagem 1 %32 Lorex LHV210800 Fan Replacement, Fan: passo 4, imagem 2 %32
    • Unplug the red and white power cord from the socket.
    • Unplug the back panel power source.
  5. Lorex LHV210800 Fan Replacement: passo 5, imagem 1 %32 Lorex LHV210800 Fan Replacement: passo 5, imagem 2 %32
    • Remove two of the 1 cm screws.
    • Remove the back panel where the fan is located.
  6. Lorex LHV210800 Fan Replacement: passo 6, imagem 1 %32 Lorex LHV210800 Fan Replacement: passo 6, imagem 2 %32
    • Turn the panel around, and locate these two black studs connecting the fan and the panel together.
    • Once you are able to get those loose using the pliers, the fan should pop out, making it easier to switch out the fan and check it for issues.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jazlyn
Membro desde: 02/19/25
197 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 151
