Introdução
The button panel is what transfers button inputs to the motherboard and controls the system directly without use of a controller. These buttons may be stuck and worn after lots of use, so the removal of the board may be necessary. The board may also need replacing due to damage.
O que você precisa
Before beginning, disconnect the DVR from power and unplug all peripheries.
Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2Comentários do guia
In the details section, there is no time estimation. It took our group 13 minutes to disassemble the dvr and put it back together.
