Ir para o conteúdo principal
Logitech Webcam Pro 9000 USB Cable Replacement
O que você precisa
  1. Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: passo 1, imagem 2 %32
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 USB Cable Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement: passo 2, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: passo 3, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: passo 3, imagem 2 %32
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  4. Logitech Webcam Pro 9000 USB Cable Replacement: passo 4, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement: passo 4, imagem 2 %32
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  5. Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: passo 5, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: passo 5, imagem 2 %32 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: passo 5, imagem 3 %32
    • Wedge the pointy end of the spudger between the sliver E-ring and USB attachment base to extract the E-ring and release the USB cable.
  6. Logitech Webcam Pro 9000 USB Cable Replacement: passo 6, imagem 1 %32 Logitech Webcam Pro 9000 USB Cable Replacement: passo 6, imagem 2 %32
    • Feed the end of the disconnected USB cable through the back cover.
Conclusão
3 outras pessoas executaram este guia.
Cory Davis
Membro desde: 04/14/13
236 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
Membros da 4
Autoria de 16 guias
4 comentários
Ich habe auch. ich braucht neu Kabel für C910 aber wo finden?
wohlgemuth1981 - Responder
where i baught pro 9000 Cable
Shiva Ji Sachan - Responder
In hindsight, I wish I had just ordered a new camera. It is more difficult than these instructions make it look. I found a replacement cable on Amazon. Disassembly and removal of the old cable was easy. Soldering of the single wire on the new cable was difficult. I'm not as steady as I used to be, and the tiny cable and small board made it a difficult task. Once I finished the soldering, reassembly was easy except for the cable clip. Once done and I plugged it in, the camera would not work--USB device not recognized. I don't know whether the cable was incorrect or if I messed something up during the soldering. I finally trashed the old camera and ordered a new Logitech c920s. Wasted $10 on the failed cable and spent $70 on the new camera.
If you are unsure, it might be worth spending the money to upgrade instead of wasting time and money on a failed replacement cable like I did.
Ron Anderson - Responder
As an update to the above-- My repair failed because I had ordered the wrong cable.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 22
Últimos 30 dias: 42
Duração total: 6,577
