Ir para o conteúdo principal
Logitech Webcam Pro 9000 Snapshot Button Replacement
O que você precisa
  1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: passo 1, imagem 2 %32
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    Pergunte ao FixBot
    Comentar
  2. Logitech Webcam Pro 9000 Snapshot Button Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 Snapshot Button Replacement: passo 2, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    Pergunte ao FixBot
    Comentar
  3. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: passo 3, imagem 1 %32 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: passo 3, imagem 2 %32 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: passo 3, imagem 3 %32
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Cory Davis
Membro desde: 04/14/13
236 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membros
Autoria de 16 guias
3Comentários do guia
Power button? Does this actually turn the camera on and off? When I push it, it seems to just pause the screen for a moment. I thought maybe it was taking still shots, but I cant seem to find a folder with any in it. I've checked all Logitech's default folder directories. (Trying to figure out what this button does, or can actually be used for.) If you want to turn a webcam off, you usually just unplug them.
Edit: Manual says its a snapshot button, but I'd love for this to start/stop OR pause recording. Hm.....
Harrison - Responder Compartilhar
I've tried to properly update this to make it more accurate, but I'm unsure how the process works. Maybe I submitted it for review? I'm not sure, but my changes have not taken effect, yet.
They were indeed submitted for approval, and have been approved! =)
Sam Goldheart - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 46
Ao todo: 2,646
