Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the two 8 mm Phillips #0 screws on the back cover.
Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
Grasp the white connector attaching the button chip wire to the motherboard.
Wiggle the connector back and forth to remove it from the connection box
Grasp the white wire connector between the tabs and the socket.
Wiggle the connector back and forth to remove the front cover from the motherboard.
Use tweezers to grasp the white wire connector on the back of the motherboard.
Wiggle the connector back and forth to remove it from the socket.
Desolder the joint on the front of the motherboard to completely detach the USB cable.
Remove the two 8mm Phillips#0 screws on the back of the motherboard.
Remove the camera from the motherboard by desoldering the two connections as shown.
Uma outra pessoa concluiu este guia.
