Ir para o conteúdo principal
Logitech Webcam Pro 9000 Microphone Replacement
O que você precisa
  1. Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 Microphone Replacement, Front and Back Cover: passo 1, imagem 2 %32
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    Pergunte ao FixBot
    Comentar
  2. Logitech Webcam Pro 9000 Microphone Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 Microphone Replacement: passo 2, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    Pergunte ao FixBot
    Comentar
  3. Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: passo 3, imagem 1 %32 Logitech Webcam Pro 9000 Microphone Replacement, Microphone Connection: passo 3, imagem 2 %32
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Logitech Webcam Pro 9000 Microphone Replacement, Microphone: passo 4, imagem 1 %32 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: passo 4, imagem 2 %32 Logitech Webcam Pro 9000 Microphone Replacement, Microphone: passo 4, imagem 3 %32
    • Wedge the plastic opening tool into the crack between the plastic cover and microphone guard.
    • Use the wedge to separate the two pieces.
    • It might take more force than expected.
    Pergunte ao FixBot
    Comentar
  5. Logitech Webcam Pro 9000 Microphone Replacement: passo 5, imagem 1 %32 Logitech Webcam Pro 9000 Microphone Replacement: passo 5, imagem 2 %32 Logitech Webcam Pro 9000 Microphone Replacement: passo 5, imagem 3 %32
    • Twist the rubber casing and remove it from the plastic cover.
    Pergunte ao FixBot
    Comentar
Conclusão
nieko
Membro desde: 04/18/13
63 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 2,471
