Ir para o conteúdo principal
Logitech UE Megaboom 4 Power Button Board Replacement
O que você precisa
  1. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: passo 1, imagem 1 %32 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: passo 1, imagem 2 %32 Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: passo 1, imagem 3 %32
    • Place the end of a metal spudger in the seam between the top cover and outer case of the speaker. Work your way around the seam of the cover to loosen it.
    • This will take force as it is glued down with the waterproofing sealant.
    • Be careful when using the metal spudger. It is sharp and can cause damage to your device and yourself.
    • Separate the top cover of the speaker from the case.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Megaboom 4 Power Button Board Replacement: passo 2, imagem 1 %32 Logitech UE Megaboom 4 Power Button Board Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove four screws from the underside of the top cover of the speaker.
    • Remove the black bracket covering the button board.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Megaboom 4 Power Button Board Replacement: passo 3, imagem 1 %32
    • Remove the circuit board from the cap.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 258
