Ir para o conteúdo principal
Logitech UE Hyperboom Power Button Board Replacement
O que você precisa
  1. Logitech UE Hyperboom Power Button Board Replacement, Handle: passo 1, imagem 1 %32 Logitech UE Hyperboom Power Button Board Replacement, Handle: passo 1, imagem 2 %32
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Hyperboom Power Button Board Replacement, Top Panel: passo 2, imagem 1 %32 Logitech UE Hyperboom Power Button Board Replacement, Top Panel: passo 2, imagem 2 %32
    • Use your hands to carefully pry the plastic cover off of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Hyperboom Power Button Board Replacement: passo 3, imagem 1 %32 Logitech UE Hyperboom Power Button Board Replacement: passo 3, imagem 2 %32 Logitech UE Hyperboom Power Button Board Replacement: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
    • Remove the top panel to access the internal components.
    • Use a metal spudger to completely disconnect the top panel.
    Pergunte ao FixBot
    Comentar
  4. Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: passo 4, imagem 1 %32 Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: passo 4, imagem 2 %32 Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: passo 4, imagem 3 %32
    • Use the Phillips #0 screwdriver to unscrew the seven 6.5mm screws on the circuit board.
    • Use a metal spudger to disconnect the power button board from the panel.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 37
Últimos 30 dias: 155
Ao todo: 228
