Ir para o conteúdo principal
Logitech UE Boom Motherboard Replacement
O que você precisa
  1. Logitech UE Boom Motherboard Replacement, D-ring: passo 1, imagem 1 %32
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Boom Motherboard Replacement: passo 2, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 2, imagem 2 %32
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Boom Motherboard Replacement, Bluetooth Adapter: passo 3, imagem 1 %32
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    Pergunte ao FixBot
    Comentar
  4. Logitech UE Boom Motherboard Replacement: passo 4, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 4, imagem 2 %32 Logitech UE Boom Motherboard Replacement: passo 4, imagem 3 %32
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Logitech UE Boom Motherboard Replacement: passo 5, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 5, imagem 2 %32
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    Pergunte ao FixBot
    Comentar
  6. Logitech UE Boom Motherboard Replacement: passo 6, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 6, imagem 2 %32 Logitech UE Boom Motherboard Replacement: passo 6, imagem 3 %32
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    Pergunte ao FixBot
    Comentar
  7. Logitech UE Boom Motherboard Replacement: passo 7, imagem 1 %32
    • With the switch plate disconnected, remove it and your device should now look like this.
    Pergunte ao FixBot
    Comentar
  8. Logitech UE Boom Motherboard Replacement, Lithium Battery: passo 8, imagem 1 %32
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
    Pergunte ao FixBot
    Comentar
  9. Logitech UE Boom Motherboard Replacement: passo 9, imagem 1 %32
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  10. Logitech UE Boom Motherboard Replacement: passo 10, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 10, imagem 2 %32 Logitech UE Boom Motherboard Replacement: passo 10, imagem 3 %32
    • Peel off the sleeve.
    Pergunte ao FixBot
    Comentar
  11. Logitech UE Boom Motherboard Replacement: passo 11, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 11, imagem 2 %32
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
    Pergunte ao FixBot
    Comentar
  12. Logitech UE Boom Motherboard Replacement: passo 12, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 12, imagem 2 %32
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
    Pergunte ao FixBot
    Comentar
  13. Logitech UE Boom Motherboard Replacement: passo 13, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 13, imagem 2 %32
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
    Pergunte ao FixBot
    Comentar
  14. Logitech UE Boom Motherboard Replacement: passo 14, imagem 1 %32
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
    Pergunte ao FixBot
    Comentar
  15. Logitech UE Boom Motherboard Replacement: passo 15, imagem 1 %32
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
    Pergunte ao FixBot
    Comentar
  16. Logitech UE Boom Motherboard Replacement: passo 16, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 16, imagem 2 %32
    • Remove the battery by pulling it from the terminal as marked in the picture.
    Pergunte ao FixBot
    Comentar
  17. Logitech UE Boom Motherboard Replacement, Motherboard: passo 17, imagem 1 %32 Logitech UE Boom Motherboard Replacement, Motherboard: passo 17, imagem 2 %32
    • Remove the speaker by pulling it from the terminal as marked in the picture.
    Pergunte ao FixBot
    Comentar
  18. Logitech UE Boom Motherboard Replacement: passo 18, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 18, imagem 2 %32
    • Remove the second speaker by pulling it from the terminal as marked in the picture.
    Pergunte ao FixBot
    Comentar
  19. Logitech UE Boom Motherboard Replacement: passo 19, imagem 1 %32 Logitech UE Boom Motherboard Replacement: passo 19, imagem 2 %32
    • Finally, remove the motherboard completely by pulling it from the terminal as marked in the picture.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Sean Reilly
Membro desde: 10/01/15
1.772 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-1, Maness Fall 2015 Membro de Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Membros
Autoria de 22 guias
2Comentários do guia
Is there anywhere I can buy the motherboard to replace my UE Boom board fried by lightning?
Mohd Razali Hamid - Responder Compartilhar
I would like to know where can I buy the UE BOOM Mother Board.
許志豪 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 82
Ao todo: 11,130
