Ir para o conteúdo principal
Logitech UE Boom Bluetooth Adapter Replacement
O que você precisa
  1. Logitech UE Boom Bluetooth Adapter Replacement, D-ring: passo 1, imagem 1 %32
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Boom Bluetooth Adapter Replacement: passo 2, imagem 1 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 2, imagem 2 %32
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Boom Bluetooth Adapter Replacement, Bluetooth Adapter: passo 3, imagem 1 %32
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    Pergunte ao FixBot
    Comentar
  4. Logitech UE Boom Bluetooth Adapter Replacement: passo 4, imagem 1 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 4, imagem 2 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 4, imagem 3 %32
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Logitech UE Boom Bluetooth Adapter Replacement: passo 5, imagem 1 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 5, imagem 2 %32
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    Pergunte ao FixBot
    Comentar
  6. Logitech UE Boom Bluetooth Adapter Replacement: passo 6, imagem 1 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 6, imagem 2 %32 Logitech UE Boom Bluetooth Adapter Replacement: passo 6, imagem 3 %32
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    Pergunte ao FixBot
    Comentar
  7. Logitech UE Boom Bluetooth Adapter Replacement: passo 7, imagem 1 %32
    • With the switch plate disconnected, remove it and your device should now look like this.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 4-1, Maness Fall 2015 Membro de Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 105
Ao todo: 12,393
