Ir para o conteúdo principal
Esta tradução pode não refletir as atualizações mais recentes do guia de fontes. Ajude a atualizar a tradução ou veja guia de fontes.
Logitech Performance MX Left Click Repair
O que você precisa
  1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: passo 1, imagem 1 %32
    • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
    Pergunte ao FixBot
    Comentar
  2. Logitech Performance MX Left Click Repair, Remove the 3 pads: passo 2, imagem 1 %32
    • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
    Pergunte ao FixBot
    Comentar
  3. Logitech Performance MX Left Click Repair, Remove the 4 screws: passo 3, imagem 1 %32
    • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
    Pergunte ao FixBot
    Comentar
  4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: passo 4, imagem 1 %32 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: passo 4, imagem 2 %32 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: passo 4, imagem 3 %32
    • Slide the bottom laterally while lifting.
    Pergunte ao FixBot
    Comentar
  5. Logitech Performance MX Left Click Repair, (optional) remove the connector: passo 5, imagem 1 %32
    • This step isn't necessary, but it makes it easier to work on the mouse.
    Pergunte ao FixBot
    Comentar
  6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: passo 6, imagem 1 %32
    • This helps to avoid losing the white piece.
    Pergunte ao FixBot
    Comentar
  7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: passo 7, imagem 1 %32 Logitech Performance MX Left Click Repair, Remove the multiswitch top: passo 7, imagem 2 %32
    • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
    Pergunte ao FixBot
    Comentar
  8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: passo 8, imagem 1 %32 Logitech Performance MX Left Click Repair, Flatten the metallic piece: passo 8, imagem 2 %32
    • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble the mouse, follow the instructions in the reverse order.
12 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
94%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Samuel Colin
Membro desde: 03/26/20
717 Reputação
Autoria de 2 guias
8Comentários do guia
merci , ca vient de sauver ma Revolution
Clement Renaut - Responder Compartilhar
Avec plaisir. J'en suis ravi :)
Samuel Colin - Responder Compartilhar
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - Responder Compartilhar
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - Responder Compartilhar
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 33
Últimos 30 dias: 230
Ao todo: 25,546
