Introdução
Use this guide remove and replace worn out mouse feet (also called skates or pads) on the bottom of a Logitech MX Vertical wireless mouse.
If thoroughly heated, the mouse feet can be cleanly removed, but you may need replacement feet if one rips or some of its adhesive is left behind.
O que você precisa
Before you begin, flip the mouse's power switch into the OFF position.
Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
5 outras pessoas executaram este guia.
