Introdução
Useful for rearranging the layout, or cleaning a key if it doesn't move right.
O que você precisa
Insert something thin under the top of the key.
Apply a little force. It comes out easily.
You've successfully removed and replaced a keycap on your Logitech MX Keys keyboard.
29 outras pessoas executaram este guia.
29Comentários do guia
Do you think the clips are durable?
No, they break easily.
Where can I find the keys for the replacement? I can only find keys for like $15 per key...
I need to know this too!
If you are having sticky key issues, take the key out, clean out the area beneath the key, and underneath the key, and reinsert the same key. In most cases, this will fix your issue. This may happen if debree/dust gets in-between the keys.
