Ir para o conteúdo principal
Logitech MBJ58 Mouse Buttons Replacement
O que você precisa
    1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: passo 1, imagem 1 %32
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Pergunte ao FixBot
      Comentar
    2. Logitech MBJ58 Mouse Buttons Replacement: passo 2, imagem 1 %32 Logitech MBJ58 Mouse Buttons Replacement: passo 2, imagem 2 %32
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Pergunte ao FixBot
      Comentar
    1. Logitech MBJ58 Mouse Buttons Replacement, Buttons: passo 3, imagem 1 %32 Logitech MBJ58 Mouse Buttons Replacement, Buttons: passo 3, imagem 2 %32
      • Locate the two tabs that are protruding from the button assembly.
      • Be careful not to break either of the two tabs by squeezing too hard.
      • Pinch the tabs together to free the buttons.
      Pergunte ao FixBot
      Comentar
    2. Logitech MBJ58 Mouse Buttons Replacement: passo 4, imagem 1 %32 Logitech MBJ58 Mouse Buttons Replacement: passo 4, imagem 2 %32
      • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
      • Slide the button assembly out from the top cover through the opening.
      • When fully disassembled, the top cover and the button assembly should look like this.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 5-14, Forte Winter 2013 Membro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Ao todo: 3,467
