Ir para o conteúdo principal
Logitech MBJ58 Mouse Button Replacement
O que você precisa
  1. Logitech MBJ58 Mouse Button Replacement, Mouse button: passo 1, imagem 1 %32
    • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
    • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
    • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
    Pergunte ao FixBot
    Comentar
    • Loosen the Phillips screw in the bottom.
    Pergunte ao FixBot
    Comentar
    • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
    • The motherboard is just plugged in and can be carefully removed forwards and upwards.
    Pergunte ao FixBot
    Comentar
    • Sensibly, first clean everything (dry).
    • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
    Pergunte ao FixBot
    Comentar
    • Everything should click together again and screws can be screwed back in. -> Loooift.
    Pergunte ao FixBot
    Comentar
Conclusão
Repeat the steps in reverse order to reassemble your device.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Tho. Hummet
Membro desde: 04/05/18
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 694
