Ir para o conteúdo principal
Logitech M515 (Couch) Mouse
O que você precisa
    1. Logitech M515 (Couch) Mouse, Removing the outer shell: passo 1, imagem 1 %32
      • Remove the battery hatch and batteries.
      Pergunte ao FixBot
      Comentar
    2. Logitech M515 (Couch) Mouse: passo 2, imagem 1 %32
      • Remove the single Phillips screw located between the battery sockets.
      Pergunte ao FixBot
      Comentar
    3. Logitech M515 (Couch) Mouse: passo 3, imagem 1 %32
      • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Anna Sweetnam
Membro desde: 04/08/10
262 Reputação
Autoria de 1 guia
4Comentários do guia
I got to step 3. where is step 4?
hawaii50 - Responder Compartilhar
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Responder Compartilhar
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Responder Compartilhar
M545 works similarly btw
Adri Idzwan Mansor - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 38
Ao todo: 5,666
