Ir para o conteúdo principal
Logitech M325c Mouse Buttons Replacement & Disassembly Guide
O que você precisa
    1. Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Gather materials & equipment: passo 1, imagem 1 %32
      • Gather all your materials and equipment together.
      • I will be using Kailh red mute switches in the build, but any two or three pin switches that fit the footprint for generic mouse switches should also work.
      Pergunte ao FixBot
      Comentar
    2. Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Housing disassembly: passo 2, imagem 1 %32 Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Housing disassembly: passo 2, imagem 2 %32
      • Take the back cover and battery off
      • Use an exacto knife or just peel away the sticker to reveal the screw hole circled in the photo
      • Unscrew the screw
      • Use your fingernail or something similar to wedge the bottom of the housing apart
      • There will be resistance from the top part of the housing, as depicted in the second photo, there are four pieces from the top and bottom housing that hold onto each other.
      • Apply horizontal pressure and press from the mouse wheel to slide the top and bottom housing apart.
      Pergunte ao FixBot
      Comentar
    3. Logitech M325c Mouse Buttons Replacement & Disassembly Guide, PCB disassembly: passo 3, imagem 1 %32 Logitech M325c Mouse Buttons Replacement & Disassembly Guide, PCB disassembly: passo 3, imagem 2 %32
      • You should now just have the PCB attached to the bottom housing.
      • There are two clips shown in the second photo that hold the PCB to the bottom housing
      • Use your fingernails or something similar to pry the clips away from the PCB.
      • After this step, the mouse wheel should detach from the PCB on its own.
      • The PCB may still be attached to the housing from the battery coil wires. Carefully remove them from the housing.
      Pergunte ao FixBot
      Comentar
    4. Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Desoldering switches and soldering: passo 4, imagem 1 %32 Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Desoldering switches and soldering: passo 4, imagem 2 %32 Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Desoldering switches and soldering: passo 4, imagem 3 %32
      • At this stage, you should have the PCB separated from the housing.
      • Desolder the two mouse switches as labeled on the second photo.
      • As the Kailh Red Mute switches only have two legs, they use only the first two holes in the PCB.
      • The third photo shows the new switches soldered onto the PCB. The switches should be aligned as shown.
      • Solder the new switches onto the PCB
      Pergunte ao FixBot
      Comentar
    5. Logitech M325c Mouse Buttons Replacement & Disassembly Guide, Reassembly: passo 5, imagem 1 %32
      • Test out the new buttons on the PCB before reassembly.
      • Make sure that both the switch on the bottom housing and the corresponding switch on the back of the PCB are both set to the OFF position.
      • Attach the PCB back to the bottom housing, with extra caution when handling the battery coil wires.
      • Attach the mouse wheel to the PCB and bottom housing.
      • Attach the top housing back to the bottom housing by sliding the top pieces of the housing together.
      • Screw the screw from the battery compartment.
      Pergunte ao FixBot
      Comentar
Conclusão
You're set!
syncope.spells
Membro desde: 03/29/24
136 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 942
