Ir para o conteúdo principal
Logitech M317C Mouse Switch Replacement
O que você precisa
    1. Logitech M317C Mouse Switch Replacement, Mouse Switch: passo 1, imagem 1 %32
      • The mouse before starting
      Pergunte ao FixBot
      Comentar
    2. Logitech M317C Mouse Switch Replacement: passo 2, imagem 1 %32
      • Flip over the mouse, removing the battery cover, USB receiver, and single Phillips 0 screw.
      Pergunte ao FixBot
      Comentar
    3. Logitech M317C Mouse Switch Replacement: passo 3, imagem 1 %32
      • Lift off the top cover of the mouse. No cables hold it in place.
      Pergunte ao FixBot
      Comentar
    4. Logitech M317C Mouse Switch Replacement: passo 4, imagem 1 %32
      • The board is held in place with several plastic clips. Use a spudger to gently push the clip next to the battery compartment. The board should raise slightly.
      Pergunte ao FixBot
      Comentar
    5. Logitech M317C Mouse Switch Replacement: passo 5, imagem 1 %32
      • Lift the board out of the mouse, towards the back of the mouse (note the clips in front).
      • Keep track of the power switch, as it may fall out when you remove the board. If it does, note the position of the on/off switch on the board and replace the switch.
      Pergunte ao FixBot
      Comentar
    6. Logitech M317C Mouse Switch Replacement: passo 6, imagem 1 %32
      • Desolder the 3 points of each switch as needed (upper and lower left solder points in photo).
      Pergunte ao FixBot
      Comentar
    7. Logitech M317C Mouse Switch Replacement: passo 7, imagem 1 %32
      • The original, non-clicking switch indicated.
      Pergunte ao FixBot
      Comentar
    8. Logitech M317C Mouse Switch Replacement: passo 8, imagem 1 %32
      • Solder the new switch into place, and reinsert the board.
      • Ensure all three clips hold the board in place, that the power switch is installed correctly, and the battery holder is inserted in the cavity at each end of the compartment.
      Pergunte ao FixBot
      Comentar
      • Reinstall the cover and test!
      Pergunte ao FixBot
      Comentar
Conclusão
Jon
Membro desde: 07/16/14
1.002 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 304
