Ir para o conteúdo principal
Logitech M310 Mouse Wheel Spring Repair
O que você precisa
  1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: passo 1, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: passo 1, imagem 2 %32
    • Check if the scroll wheel is spinning freely without resistance.
    • A correctly aligned spring will cause the wheel to ratchet in small increments
    Pergunte ao FixBot
    Comentar
  2. Logitech M310 Mouse Wheel Spring Repair: passo 2, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair: passo 2, imagem 2 %32 Logitech M310 Mouse Wheel Spring Repair: passo 2, imagem 3 %32
    • Use your thumb to press the indentation on the bottom battery cover.
    • Slide down the battery cover and fully remove the battery cover.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Logitech M310 Mouse Wheel Spring Repair: passo 3, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair: passo 3, imagem 2 %32 Logitech M310 Mouse Wheel Spring Repair: passo 3, imagem 3 %32
    • Remove two Phillips #1 screws.
    Pergunte ao FixBot
    Comentar
  4. Logitech M310 Mouse Wheel Spring Repair: passo 4, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair: passo 4, imagem 2 %32 Logitech M310 Mouse Wheel Spring Repair: passo 4, imagem 3 %32
    • Remove the bottom board plate from the mouse body by pulling it down and away.
    • Ensure not to apply the force perpendicular to the mouse body. The board will only remove in a downward direction.
    Pergunte ao FixBot
    Comentar
  5. Logitech M310 Mouse Wheel Spring Repair: passo 5, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair: passo 5, imagem 2 %32 Logitech M310 Mouse Wheel Spring Repair: passo 5, imagem 3 %32
    • Use the 2mm flat head to lift up the spring leg.
    • Use the screwdriver as a lever to pry the spring leg back into the scroll wheel
    • You may need to use your thumb to pull the scroll wheel to the left a few millimeters, creating enough of a gap on the right side for the spring leg to fit into the mouse wheel cavity.
    • The spring leg should no longer be visible once aligned inside the mouse wheel cavity.
    Pergunte ao FixBot
    Comentar
  6. Logitech M310 Mouse Wheel Spring Repair: passo 6, imagem 1 %32 Logitech M310 Mouse Wheel Spring Repair: passo 6, imagem 2 %32 Logitech M310 Mouse Wheel Spring Repair: passo 6, imagem 3 %32
    • Before reassembling the mouse, confirm if the scroll wheel is fixed appropriately.
    • Gently place the mouse down on the table and scroll the wheel. There should now be a noticeable difference in resistance, and it should no longer freely spin.
    • If the scroll wheel is still not fixed, you may need to readjust the spring into the cavity again (see Step 5).
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Equipe
UC Davis, Team S2-G2, Andersen Winter 2020 Membro de UC Davis, Team S2-G2, Andersen Winter 2020
UCD-ANDERSEN-W20S2G2
4 Membros
Autoria de 3 guias
9Comentários do guia
Great tutorial. I thought I needed to buy another one. With this I managed to fix it under 2 minutes. Thanks! :)
StopShop GSM - Responder Compartilhar
Excellent instructions, I searched the web for days looking for the solution. I could not determine if it was software or hardware, the mouse wheel has always spun free, no clicking. After following your instructions, it clicks when I scroll and the spontaneous jumping is gone. Thanks a million!
Bob Weenig - Responder Compartilhar
Fantastic instructions! I was struggling to find out how the spring should be placed for the proper ratcheting behavior. This walk-through got me there in less than a minute. Thank you very much!
Sean Smith - Responder Compartilhar
Is there any way to replace the spring if lost?
Connor - Responder Compartilhar
Thanks so much for the great tutorial. The pictures really helped.
Maureen - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 58
Últimos 30 dias: 200
Ao todo: 12,292
