Ir para o conteúdo principal
Logitech M215 Battery Replacement
O que você precisa
    1. Logitech M215 Battery Replacement, Remove the battery cover: passo 1, imagem 1 %32 Logitech M215 Battery Replacement, Remove the battery cover: passo 1, imagem 2 %32 Logitech M215 Battery Replacement, Remove the battery cover: passo 1, imagem 3 %32
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      Pergunte ao FixBot
      Comentar
    2. Logitech M215 Battery Replacement, Remove old battery: passo 2, imagem 1 %32
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      Pergunte ao FixBot
      Comentar
Conclusão
28 outras pessoas executaram este guia.
Hannah Pate
Membro desde: 01/30/15
1.742 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 1-1, Watkins Winter 2015 Membro de USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Membros
Autoria de 28 guias
10Comentários do guia
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - Responder Compartilhar
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - Responder Compartilhar
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - Responder Compartilhar
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - Responder Compartilhar
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 51
Últimos 30 dias: 243
Ao todo: 124,293
