Ir para o conteúdo principal
Logitech Harmony Touch Buttons Replacement
O que você precisa
  1. Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, imagem 1 %32 Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, imagem 2 %32 Logitech Harmony Touch Buttons Replacement, Buttons: passo 1, imagem 3 %32
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
    Pergunte ao FixBot
    Comentar
  2. Logitech Harmony Touch Buttons Replacement: passo 2, imagem 1 %32 Logitech Harmony Touch Buttons Replacement: passo 2, imagem 2 %32 Logitech Harmony Touch Buttons Replacement: passo 2, imagem 3 %32
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Logitech Harmony Touch Buttons Replacement: passo 3, imagem 1 %32 Logitech Harmony Touch Buttons Replacement: passo 3, imagem 2 %32 Logitech Harmony Touch Buttons Replacement: passo 3, imagem 3 %32
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
    Pergunte ao FixBot
    Comentar
  4. Logitech Harmony Touch Buttons Replacement: passo 4, imagem 1 %32 Logitech Harmony Touch Buttons Replacement: passo 4, imagem 2 %32
    • Remove the buttons from the case.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 1,893
