Ir para o conteúdo principal
Logitech Harmony Smart Keyboard On/Off Switch Replacement
O que você precisa
  1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: passo 1, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: passo 1, imagem 2 %32
    • Turn keyboard over to the backside.
    Pergunte ao FixBot
    Comentar
  2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 2, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 2, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 2, imagem 3 %32
    • Press and slide up on the upper battery latch, using both thumbs.
    Pergunte ao FixBot
    Comentar
  3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 3, imagem 1 %32
    • Remove the two AA batteries and set them aside.
    Pergunte ao FixBot
    Comentar
  4. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 4, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 4, imagem 2 %32
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 5, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 5, imagem 2 %32
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 6, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 6, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 6, imagem 3 %32
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 7, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 7, imagem 2 %32
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
    Pergunte ao FixBot
    Comentar
  8. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 8, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 8, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 8, imagem 3 %32
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
    Pergunte ao FixBot
    Comentar
  9. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 9, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 9, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 9, imagem 3 %32
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
    Pergunte ao FixBot
    Comentar
  10. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: passo 10, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: passo 10, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: passo 10, imagem 3 %32
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
    Pergunte ao FixBot
    Comentar
  11. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 11, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 11, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 11, imagem 3 %32
    • Set aside the front panel and locate the green card atop the on/off switch on the back panel.
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 12, imagem 1 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 12, imagem 2 %32 Logitech Harmony Smart Keyboard On/Off Switch Replacement: passo 12, imagem 3 %32
    • Lift up and hold the left side of the green card with one index finger.
    • Grip and pull the on/off switch out with your other index finger and thumb.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Membro de CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Membros
Autoria de 10 guias
1Comentário do guia
please share switch rear side.. and where could we buy this switch.. ?
Praveen Krishnan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 56
Ao todo: 5,207
