Ir para o conteúdo principal
Logitech Harmony Smart Control Reset Button Replacement
O que você precisa
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: passo 1, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: passo 1, imagem 2 %32
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: passo 2, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 2, imagem 2 %32
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: passo 3, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 3, imagem 2 %32
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: passo 4, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 4, imagem 2 %32
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: passo 5, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 5, imagem 2 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 5, imagem 3 %32
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: passo 6, imagem 1 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 6, imagem 2 %32 Logitech Harmony Smart Control Reset Button Replacement: passo 6, imagem 3 %32
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Conclusão
Equipe
IUPUI, Team 3-2, Harley Fall 2015 Membro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 28
Ao todo: 1,139
