Ir para o conteúdo principal
Logitech Harmony Smart Control Remote Buttons Replacement
O que você precisa
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: passo 1, imagem 1 %32 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: passo 1, imagem 2 %32
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
    Pergunte ao FixBot
    Comentar
  2. Logitech Harmony Smart Control Remote Buttons Replacement: passo 2, imagem 1 %32 Logitech Harmony Smart Control Remote Buttons Replacement: passo 2, imagem 2 %32
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
    Pergunte ao FixBot
    Comentar
  3. Logitech Harmony Smart Control Remote Buttons Replacement: passo 3, imagem 1 %32 Logitech Harmony Smart Control Remote Buttons Replacement: passo 3, imagem 2 %32
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
    Pergunte ao FixBot
    Comentar
  4. Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, imagem 1 %32 Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, imagem 2 %32 Logitech Harmony Smart Control Remote Buttons Replacement: passo 4, imagem 3 %32
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
    Pergunte ao FixBot
    Comentar
  5. Logitech Harmony Smart Control Remote Buttons Replacement: passo 5, imagem 1 %32
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
Josh Hendricks
Membro desde: 09/17/15
464 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 3-2, Harley Fall 2015 Membro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membros
Autoria de 5 guias
10Comentários do guia
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Responder Compartilhar
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde - Responder Compartilhar
Where do you purchase button replacements?
Steve Lutes - Responder Compartilhar
Flavio Campos - Responder Compartilhar
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 34
Ao todo: 6,445
