Introdução
Learn how to disassemble the Logitech Harmony Smart Control hub, remove a burned out or defective light bulb or bulb(s), and replace it with new one(s).
This repair requires soldering. View the soldering guide at:
O que você precisa
Use a spudger to lift up one of the rubber pads on the bottom of the hub.
Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
Repeat for the second rubber pad.
