Introdução
This guide requires soldering, for soldering guide click below.
O que você precisa
Use the plastic opening tool to lift up the rubber pad.
With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
Repeat the step above for the second rubber pad on the bottom of the hub.
Uma outra pessoa concluiu este guia.
