Ir para o conteúdo principal
Logitech Harmony Smart Control Charging Port Replacement
Josh Hendricks
Josh Hendricks e 4 outros colaboradores
Última atualização em May 23, 2016
10 - 20 minutos
Difícil
This guide requires soldering, for soldering guide click below.
Soldering Guide
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: passo 2, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 2, imagem 2 %32
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: passo 3, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: passo 4, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 4, imagem 2 %32
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: passo 5, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 5, imagem 2 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 5, imagem 3 %32
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: passo 6, imagem 1 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 6, imagem 2 %32 Logitech Harmony Smart Control Charging Port Replacement: passo 6, imagem 3 %32
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Conclusão
Uma outra pessoa concluiu este guia.
Josh Hendricks
Membro desde: 09/17/15
464 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 3-2, Harley Fall 2015 Membro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 762
