Ir para o conteúdo principal
Logitech Harmony Smart Control Battery Contact Replacement
O que você precisa
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: passo 1, imagem 1 %32 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: passo 1, imagem 2 %32
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: passo 2, imagem 1 %32 Logitech Harmony Smart Control Battery Contact  Replacement: passo 2, imagem 2 %32
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, imagem 1 %32 Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, imagem 2 %32 Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, imagem 3 %32
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: passo 4, imagem 1 %32 Logitech Harmony Smart Control Battery Contact  Replacement: passo 4, imagem 2 %32
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: passo 5, imagem 1 %32
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Conclusão
Josh Hendricks
Membro desde: 09/17/15
464 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team 3-2, Harley Fall 2015 Membro de IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membros
Autoria de 5 guias
1Comentário do guia
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 39
Ao todo: 5,254
