Ir para o conteúdo principal
Logitech Harmony 650 Button Replacement
O que você precisa
  1. Logitech Harmony 650 Button Replacement, Case: passo 1, imagem 1 %32 Logitech Harmony 650 Button Replacement, Case: passo 1, imagem 2 %32
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    Pergunte ao FixBot
    Comentar
  2. Logitech Harmony 650 Button Replacement: passo 2, imagem 1 %32
    • Remove the batteries using the silver pull tab.
    Pergunte ao FixBot
    Comentar
  3. Logitech Harmony 650 Button Replacement: passo 3, imagem 1 %32
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    Pergunte ao FixBot
    Comentar
  4. Logitech Harmony 650 Button Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    Pergunte ao FixBot
    Comentar
  5. Logitech Harmony 650 Button Replacement: passo 5, imagem 1 %32
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    Pergunte ao FixBot
    Comentar
  6. Logitech Harmony 650 Button Replacement: passo 6, imagem 1 %32 Logitech Harmony 650 Button Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    Pergunte ao FixBot
    Comentar
  7. Logitech Harmony 650 Button Replacement: passo 7, imagem 1 %32
    • Remove the rear cover.
    Pergunte ao FixBot
    Comentar
  8. Logitech Harmony 650 Button Replacement, Motherboard: passo 8, imagem 1 %32 Logitech Harmony 650 Button Replacement, Motherboard: passo 8, imagem 2 %32
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
    Pergunte ao FixBot
    Comentar
  9. Logitech Harmony 650 Button Replacement: passo 9, imagem 1 %32
    • Remove the motherboard by gently pulling it away from the case.
    Pergunte ao FixBot
    Comentar
  10. Logitech Harmony 650 Button Replacement, Button: passo 10, imagem 1 %32
    • Using a spudger, gently pry the bottom retaining place from the front case.
    Pergunte ao FixBot
    Comentar
  11. Logitech Harmony 650 Button Replacement: passo 11, imagem 1 %32 Logitech Harmony 650 Button Replacement: passo 11, imagem 2 %32
    • Peel away both the upper and lower sets of buttons using your fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
8Comentários do guia
Good instructions. Where can I purchase new buttons???
Michael Freeman - Responder Compartilhar
Hello, I would recommend looking on eBay for a broken remote with a good membrane, also check craigslist or potentially amazon. A quick search for one and I couldn't find a membrane.
Austin K - Responder Compartilhar
I also am looking for a new button membrane, any ideas? gimmick73@hotmail.com
gimmick73 - Responder Compartilhar
Good advice. I bought a used one from ebay to replace the one I bought brand new from bestbuy and promptly broke the screen by dropping it on the kitchen floor. I plan on replacing the worn buttons on the working used replacement with the buttons from my broken one, and perhaps the case as well. Will let you know how it works out.
Jeremiah Behrens - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 57
Ao todo: 14,693
