Introdução
If your triggers on your Logitech Gamepad F310 seem to be loose or broken, you might need to replace the springs inside them. Luckily this is a fairly easy process. Follow this guide to replace the springs on the triggers for your Gamepad controller.
The trigger spring is to help make trigger return back original position. The trigger is special function for gaming purpose like aiming, zooming and etc. So those are reason to replace trigger spring.
No special tools or skills are required.
O que você precisa
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Use a Phillips #1 screwdriver to remove:
Four 3 mm screws
One 5 mm screw
Gently lift the motherboard off of the back case and slide the cord out of the top slot.
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
Uma outra pessoa concluiu este guia.
1Comentário do guia
I completed this guide in conjunction with this video:
