Ir para o conteúdo principal
Logitech Gamepad F310 Buttons Replacement
O que você precisa
  1. Logitech Gamepad F310 Buttons Replacement, Case: passo 1, imagem 1 %32 Logitech Gamepad F310 Buttons Replacement, Case: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Pergunte ao FixBot
    Comentar
  2. Logitech Gamepad F310 Buttons Replacement: passo 2, imagem 1 %32 Logitech Gamepad F310 Buttons Replacement: passo 2, imagem 2 %32
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Pergunte ao FixBot
    Comentar
  3. Logitech Gamepad F310 Buttons Replacement: passo 3, imagem 1 %32
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Pergunte ao FixBot
    Comentar
  4. Logitech Gamepad F310 Buttons Replacement, Buttons: passo 4, imagem 1 %32 Logitech Gamepad F310 Buttons Replacement, Buttons: passo 4, imagem 2 %32
    • Remove any buttons that need replacement.
    • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
    Pergunte ao FixBot
    Comentar
Conclusão
You're all finished! To reassemble your device, follow these instructions in reverse order.
1Comentário do guia
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 68
Ao todo: 1,407
