Ir para o conteúdo principal
Logitech G915 TKL Keyswitch Replacement
O que você precisa
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: passo 1, imagem 1 %32 Logitech G915 TKL Keyswitch Replacement, Keyswitch: passo 1, imagem 2 %32
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: passo 2, imagem 1 %32 Logitech G915 TKL Keyswitch Replacement: passo 2, imagem 2 %32
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: passo 3, imagem 1 %32 Logitech G915 TKL Keyswitch Replacement: passo 3, imagem 2 %32
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: passo 4, imagem 1 %32
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: passo 5, imagem 1 %32
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: passo 6, imagem 1 %32
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
Conclusão
Ethan Bedard
Membro desde: 03/13/23
485 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-6, Petersen Spring 2023 Membro de UMass Dartmouth, Team 3-6, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G6
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 37
Últimos 7 dias: 248
Últimos 30 dias: 1,029
Duração total: 13,124
