Ir para o conteúdo principal
Logitech G733 Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Logitech G733 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the right ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
    • Remove the ear pad.
    Pergunte ao FixBot
    Comentar
  2. Logitech G733 Battery Replacement: passo 2, imagem 1 %32 Logitech G733 Battery Replacement: passo 2, imagem 2 %32
    • Remove the four screws that secure the speaker housing using a Phillips screwdriver.
    • Place these screws on the magnetic pad so you don't lose them.
    Pergunte ao FixBot
    Comentar
  3. Logitech G733 Battery Replacement: passo 3, imagem 1 %32 Logitech G733 Battery Replacement: passo 3, imagem 2 %32 Logitech G733 Battery Replacement: passo 3, imagem 3 %32
    • Lift off the speaker housing with care not to strain the connected cable.
    • Gently wiggle the white battery cable connector side to side while pulling it out to disconnect the battery.
    • Do not pull on the wires.
    Pergunte ao FixBot
    Comentar
  4. Logitech G733 Battery Replacement: passo 4, imagem 1 %32
    • Take care not to puncture, twist, or bend the battery as you pry.
    • Remove the battery, using a spudger to gently pry it up if necessary.
    • Reapply adhesive, put the new battery in place, and plug it in.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, please follow these instructions in reverse order.
6 outras pessoas executaram este guia.
5Comentários do guia
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
Darbii Rue - Responder Compartilhar
I fully agree
Gabriel Nunes - Responder Compartilhar
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
Heather Dasher - Responder Compartilhar
took 2 mins to find battery info ..........................
Logi 533-000181
Stephen Burrows - Responder Compartilhar
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
Jad Ghanayem - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 102
Ao todo: 17,270
