Ir para o conteúdo principal
Logitech G710+ Disassembly
O que você precisa
  1. Logitech G710+ Disassembly, Body: passo 1, imagem 1 %32
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
    Pergunte ao FixBot
    Comentar
  2. Logitech G710+ Disassembly, Mother board: passo 2, imagem 1 %32 Logitech G710+ Disassembly, Mother board: passo 2, imagem 2 %32 Logitech G710+ Disassembly, Mother board: passo 2, imagem 3 %32
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
    Pergunte ao FixBot
    Comentar
  3. Logitech G710+ Disassembly, Scroll Wheel: passo 3, imagem 1 %32
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
    Pergunte ao FixBot
    Comentar
  4. Logitech G710+ Disassembly, Pads: passo 4, imagem 1 %32
    • You can then take off the little pads
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Jackson Poer
Membro desde: 04/08/17
695 Reputação
Autoria de 2 guias
3Comentários do guia
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - Responder Compartilhar
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - Responder Compartilhar
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 27
Últimos 30 dias: 83
Ao todo: 9,698
