Ir para o conteúdo principal
Logitech G502 Proteus Core Mouse Feet Replacement
O que você precisa
    1. Logitech G502 Proteus Core Mouse Feet Replacement, Mouse Feet: passo 1, imagem 1 %32 Logitech G502 Proteus Core Mouse Feet Replacement, Mouse Feet: passo 1, imagem 2 %32 Logitech G502 Proteus Core Mouse Feet Replacement, Mouse Feet: passo 1, imagem 3 %32
      • Use your fingers or a nylon spudger to peel the old feet off all three corners where the screw holes are exposed.
      Pergunte ao FixBot
      Comentar
    2. Logitech G502 Proteus Core Mouse Feet Replacement: passo 2, imagem 1 %32 Logitech G502 Proteus Core Mouse Feet Replacement: passo 2, imagem 2 %32 Logitech G502 Proteus Core Mouse Feet Replacement: passo 2, imagem 3 %32
      • Peel the backing off the new mouse feet to reveal the adhesive.
      Pergunte ao FixBot
      Comentar
    3. Logitech G502 Proteus Core Mouse Feet Replacement: passo 3, imagem 1 %32 Logitech G502 Proteus Core Mouse Feet Replacement: passo 3, imagem 2 %32 Logitech G502 Proteus Core Mouse Feet Replacement: passo 3, imagem 3 %32
      • Apply the new mouse feet to their designated areas based on shape.
      Pergunte ao FixBot
      Comentar
    4. Logitech G502 Proteus Core Mouse Feet Replacement: passo 4, imagem 1 %32
      • Apply even pressure across the mouse feet to ensure adherence.
      Pergunte ao FixBot
      Comentar
    5. Logitech G502 Proteus Core Mouse Feet Replacement: passo 5, imagem 1 %32
      • Let adhesive sit for about 5-10 minutes with applied pressure.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Sage Farray
Membro desde: 04/10/17
547 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G1, Liner Spring 2017 Membro de UW Tacoma, Team S3-G1, Liner Spring 2017
UWT-LINER-S17S3G1
4 Membros
Autoria de 17 guias
1Comentário do guia
You completely omitted half of the feet located on the mouse. The ones left out are the 3 located on the removable panel: there are 2 “v” shaped ones around the sensor and the one to the right of the “v” shapes.
Robert - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 57
Ao todo: 11,852
